Screen Ilumination starts blinking
variant
I recently bought an an xperia go. I had installed ICS by default. Sometimes, when unlocking the screen, the illumination of the screen start blinkig, just like it had a very low screen refresh rate, but only in the backlite. I upgraded do JB, and the problem persists, and when it happens the only way to stop, is locking the screen and unlock. It doesnt happen much.. but usually happens when seeing bright images, or white backgrounds. Anyone notice this bug?
Thanks
Alexander1
Do you have the auto brightness settings for the display activated? If you have, try to uncheck it and see if the problem persists. The screen may flicker a bit when it adjusts the brightness depending on the surroundings.
If the problem still persists you should the send into service for repair. Please contact your local Xperia support for more information.
