screen fault
Maximmus
screen fault
I bought Sony Xperia z2 two weeks ago. Yesterday I noticed that there are two blue circles appear in the middle of the screen when the color is black. They don't show on any other color. What should I do?
7 REPLIES 7
profile.country.RO.title
_alexdon_
Has anything happened to the device? A drop or anything like that?
alexdon
Maximmus
Not at all.
Maximmus
I have made a reset to factory settings but nothing happenen
_alexdon_
You may need to perform a software repair using PC Companion.The process will erase all internal memory.You might need to charge your device for about 1-2 hours before so the device has at least 60% battery.
If the above does not help,you should take the device back.
alexdon
Maximmus
Happened
Maximmus
Thanks. I will.
_alexdon_
Keep us updated.
alexdon
