Scala Rider Q1 does not 'ring' or react to Xperia ZR in Dutch
Eric_ZR
While connecting with BT is OK, the headset in my helmet does not 'ring' when a call is coming in, nor can I accept the call by voice (any word/sound). I am able to use the 'hot line' (one number) and the connection is clear. But it is absolutely not possible to voice dial via Sony as the phone does not understand my Dutch contact names... Parrot and Google do not have this problems and understand me perfectly... So Sony/Android, what can be done?! Or other users, what solution did you find?
2 REPLIES 2
Alan555871
Yes, I have the same problem. I can connect to my BT handsfree set but the phone behaves as if it's not there and rings normally.
Are you running the latest ROM? [ 10.3.1.A.2.67 ], I think there is a fault in it as there are other threads here saying the problem appeared after that update.
My ZR came with that ROM so I don't know if the previous release worked or not.
Yorgio
Hi, i dont have that problem but im from Colombia and i use Spanish.  But i have a problem, the music playback slows down with my scala rider Q1, does that happen to yoou?
