Is there any way to make the homescreen rotet without the placing the phone in the dock??
I don't think this is possible.
Not the homescreen unfortunately.
But since it does rotate the homescreen when placed in the dock, it means it CAN rotate it. Then I don't see any reason why it shouldn't do this also when the phone is held sideways? Or is there some part of it that's not functional in landscape mode?
Exactly my point!! I sure hope they fix that with the next update!! :-B
even my old motorola defy can rotate the homescreen
@scuccria if you read the bottom of the picture
*icons are for illustrative purposes only.
Older Xperia phones do have that settings. But apparently Sony has ecide to forgo that. Not sure why.:smileyhappy:
However, you can set auto-roate yourself by installing apps from Google Play. I'm using "Screen Rotation" for that, But the settings do not 'stick'. You have to run the apps again when you restart your phone. There are a lot of similar apps in Play. Maybe you can find out that stick.
That photo could be taken while using the sceen mirroring feature to a Sony TV. Once connected you can rotate the screen.
