Rooting Questions
ryan515
Rooting Questions
Hello,
How many of you root their Xperia P?
What is the advantage of rooting your phone?
Is it a MUST do to your Xperia P?
Will it Void my warranty?
Can I unroot after i root?
Sorry for too many questions.
I'm just curious because I saw a camera mod on XDA for Xperia phones.
It looks like one on the Xperia T and V.
Did anyone try that?
26 REPLIES 26
ryan515
anybody?
aayushjain1987
I have rooted my Xperia from day one :smileygrin:
By rooting, you can use Ad Blocker to prevent apps from showing apps. which saves battery and data usage noticably and apps load faster.
You can pause/ remove any unwanted app that is by default installed in your formware using titanium backup pro.
you need to install SUPERUSER ELITE to set a password to avoid unwanted root access.
Root doesnot void your warranty unless your changes dont affect hardware, stopping or rmeoving a wrong app can crash the phone, you then have to refalsh the OS.
backup and restore for each app is easy and many more...............
ryan515
seems like there are some very good advantage of rooting the phone. How can i back up?
Is there step by step on how to root it?
and did you tried using MODS from XDA like this one?
http://forum.xda-developers.com/showthread.php?t=1950862
aayushjain1987
First purchase these two apps and get familiar with them. they will help you restore your data in case somehting goes wrong and you have to format the phone .
https://play.google.com/store/apps/details?id=com.keramidas.TitaniumBackupPro&feature=search_result#...
https://play.google.com/store/apps/details?id=com.bigtincan.adfree&feature=search_result#?t=W251bGws...
https://play.google.com/store/apps/details?id=com.noshufou.android.su.elite&feature=search_result#?t...
there are many things you can do. but i advise you to go slowly.
ryan515
I should purchase them all first? and then my phone will be rooted?
ryan515
aayushjain1987
These apps will not root your phone. but help you to gain more from rooting.
Titanium backup is like a life saver app . if ever something goes horribly wrong and you are forced to reset your phone. this app wil help you to restore your phone to the last working state you have backedup  as easy as saying 1-2-3 :smileygrin: :smileygrin:
purchasing superuser elite is just difference between setting lock screen to SLIDE or PASSWORD .
prevents apps to gain unauthorised root access.
use this method combined with previous one :
http://forum.xda-developers.com/showthread.php?t=2023756
you also need to get familiar with flashtool . which will be helpful for you if you ever plan to FLASH the stock rom or custom rom .
you need to do lot of searching and reading on XDA .
more you read , more comfortable you feel. sometimes learnign from others bad experiecnse helps you revocer form your own. if ever you face same.
also downlaod a ROOT BROWSER app from paly store. to make system modifications
https://play.google.com/store/apps/details?id=pl.solidexplorer&feature=search_result#?t=W251bGwsMSwx...
i advise you to go slowly, dont rush into things. you might get messed up with all data lost.
dont go bootloader unlocking as of now, it WILL SURELY VOID YOUR WARRANTY .
also i would recommend you to use this app.
https://play.google.com/store/apps/details?id=com.sp.protector.free&feature=search_result#?t=W251bGw...
and set password for apps whicvh let you modify system. so that unwanted persons cant mess up your phone.
:smileygrin: :smileygrin: :smileygrin:
ryan515
So step 1) I should format my phone and internal storage.
2.) Use the titanium backup to back up my current ROM?
3.) And then root my mobile?
aayushjain1987
Format not required for rooting.
