Sometimes Even my ringtone/alert level is half, my keypad click sound makes too much of sound as if i've given full volume to keypad click and the same happens for message alerts also. Even if i reduce the volume it sounds too loud as like before. And to make it worse, even if i keep my cell in vibration mode, keypad click sound is too high(While typing message and other keypad tasks). It becomes normal if i restart the phone. Any suggestions?
I would run an update/repair:
and install it on your PC.
4. Phone Software Update.
5. Start.
6. Repair Phone
7. Continue
8. Accept data removal
9. Next
10. Wait for prepare
11. Select Phone
12. Follow the connection steps
Hi sam, I think software repair is not the solution for each and every simple issue.. Even if we repair the problem persists, i've tried it.
