Ringtone changes after restarting
johwhite30
New
Software version: 11.2.A.0.21
Whenever my Xperia J is restarted it can't find the ringtone that I have selected. I am using a custom MP3 ringtone that is stored on the phone (no SD card in phone). I set the ringtone and it works ok until I turn the phone off. When I turn the phone back on it goes back to a preinstalled ringtone. When I go to select the ringtone again it just says "unknown ringtone". If I then go into select a ringtone and then goto Music Library it then says "Music Library Empty", which it isn't. After several attempts to goto the music llibrary it finally recognises that there is music in there that i can select.
Any ideas?
8 REPLIES 8
Samuel1
Hero
Sounds like there might be something wrong with the media scanner in the phone. Try open up Settings > Apps > All. Find the apps called "ProtectedMediaScanner" and "ProtectedMediaScannerTrigger" and clear data for these apps. Restart the phone, set the ringtone and restart the phone again to see if it worked.
Praha
Sir, i too face this issue... also many other issues like
frequent restart,
low headphone volume
touchscreen going freezed often..
i tired with update service, PC companion and also gave the phone to a service center.. still the problem is occuring... kindly consider this as JB feedback for xperia J and provide an update that solves these issues...
johwhite30
New
Hi. Thanks for the reply. I went to try your suggested fix but there are no apps called "ProtectedMediaScanner" and "ProtectedMediaScannerTrigger" so I can't clear the data on them.
Samuel1
Hero
Which software are you running in your phone? (Settings > About phone > Software/build number)
johwhite30
New
I put it in the first post: Software version: 11.2.A.0.21
Milzam_ma
can sony fix this problem?
johwhite30
New
Any update on this? Should I be returning the phone as faulty?
madara
i have the same problem and i am running in build number 11.2.A.0.31
and i do not have a "ProtectedMediaScanner" and the other media scanner on my xperia j
