Restricted access changed
ar84
I using Sony Xperia Z (C6603) since jan 17, 2014. my operating system is 4.3 jelly bean. sometimes a notification displayed that "Restricted access changed emergency service is blocked". i don't know why this type of notification displayed and how will i solve/stop this problem/notification.
Pls help me above mentioned notification to stop.
15 REPLIES 15
100rabh
I just got this notification arnd 12 .. whats going on ?? any problem ??
nasirbp
I also face the same problem. I'm from Bangladesh operator grammenphone and banglalink. Xperia m2 dual,android 4.4 os
Scouseknight
Selecting the mobile network mode and provider does not solve the problem unfortunately - at least, not for me.
I've been experiencing this problem (Restricted access changed Data service blocked) since 16/01/2015 - it disappears briefly then appears again.
I even tried a factory reset on the phone (luckily I've only had it a short time).
I have the X1 Compact phone with the Virgin Mobile provider.
RajuSaboo
This worked for my Sony M2 Dual
kinakat
Does anyone has an update on this? I started having the problem on 1st August after a major festival that blocked most networks. Days later I still have the issue and I noticed my mobile data isn't working anymore. WiFi is perfect, but no mobile internet. I went to the operator shop today that told me it could be a virus and to hard reset the phone, I did it but I knew it wouldn't help. I will go and demand to try swap the sim with one that has working internet mobile and see if the issue lays on their side or mine. It was fine and then all of a sudden this Slightly_frowning_Face I have tried manually changing the Network Operator but nothing helped.
Droidislife
You can actually use apps like notify block to stop the "restricted access changed service blocked" notification on your Android phone. The app will simply restrict this restricted access notification for both data and voice services: http://valuestuffz.blogspot.com/2016/05/fix-restricted-access-changed-service-blocked-notification-a...
