How do I repair my Sony xperia z1
Performing a system repair using PC Companion - This will factory reset your phone and erase all data
Hi nonu1910, welcome to the community!
Also, if you can power your handset on and unlock the screen then you can back up data beforehand.
1. Start PC Companion on the computer.
2. Connect your phone to the computer using a USB cable.
3. Click Start under Backup & Restore.
4. Follow the on-screen instructions.
(Exactly what contents will be backed up may differ depending on phone model.
You can view detailed information about this as you follow the steps in the Backup & Restore wizard).
