remove widgets from front screen?
How do i change the widgets from the front scren?
Also i have a half page fb as front page how do i remove?
To remove a widget, just long-press on it until the phone vibrates and then drag it to the trashbin that appears at the bottom of the screen. To add widgets, just long-press on any part of the homescreen until the menu comes up, select Widgets then select the one(s) you want to add. Hope this helps!
