Hello Guys.
coming straight to the point, I was changing my Xperia Play's display. I did well. but before pakaging I want to be sure that display working fine or not. I connect battery to terminal and press On Switch but it wont turn on. Suddenly I saw the Battery It connected Wrong. Means +ve connect to -ve And vice versa.
Now When I put battery and try to on it, the RED Light present in Power Button Blinks. When I connect charger to it It Flashes Once and Than Continously Remains Red. Battery Become hot during charging Process.
Please Help me.
Maybe it was the battery problem or something going wrong with your phone when you disassemble the display and cause hardware failure.
your batery is damage i think..
change your btery
I haven't try to change the battery. let me be replace the battery and i will tell you soon weather it turn on by replacing battery or not. thank you for suggestion.
i have try to change battery, now when we put it on charging it still blinking red light same again, but when we remove charger and try to on it its vibrates and a green light blink once, it feels like it is on, but no display and no display lights, mobile motherboard heats up and battery too...
In this case it would be worth while running a software update to potentially resolve this issue. This can be performed with the phone off, just ensure you do not have it connected to the PC when you start:
1. Download the PC Companion software from http://www.sonymobile.com/gb/tools/pc-companion/
and install it on your PC.
2. Install and open PC Companion then select Support Zone.
3. Phone Software Update.
4. Start.
5. Repair Phone
6. Continue
7. Accept data removal
8. Next
9. Wait for prepare
10. Select Phone
11. Follow the connection steps
phone not connecting... at Phone Software update window------> 2. Prepare...
at this windows phone not detecting.
my laptop windows gives a notification bubblethat: USB Device Not Recognized.
i found another thing today. I remove the battery and plug in charger. it blinks red light constantly even there is no battery installed....
To solve the issue, open Device Manager on your computer to reinstall the driver for your device while your device is connected with your PC via a USB cable.
Microsoft Windows Vista and 7 users
To open Device manager on your computer
Click on the Start button.
In the Search box, type device manager, and then press enter.
Microsoft Windows 8 users
Click the Desktop Tile to open the Desktop.
Click >> at the bottom right of the taskbar.
Select Control Panel from the Menu.
Select Device Manager from the list of control panel items.
Note: If you do not see the screen with the Device Manager option, click the View by drop-down menu and select Small icons.
Microsoft Windows XP and 2000 users
On the desktop, right-click on My Computer and click Properties.
In the System Properties window, click the Hardware tab.
In the Hardware, tab click the Device Manager button.
To reinstall the drivers for your device
Scroll down to the Universal Serial Bus controllers (USB section) of the Device Manager window.
Look for an MTP Device: Media Device, Unknown Device or any other reference to your phone. Click on this entry and choose "Uninstall" whilst leaving the device connected.
Wait a few minutes, and the computer will reinstall the drivers for the device.
Now, the phone is accessible via Computer/My Computer on your computer.
I am Using Windows 8
Should I turn Windows Update on From Action Center?
I Try Both way turning on and off too. Nothing Happen. still windows msg showing USB Device Not Recognised.
Device manager shows this phone as:
Other Devices-> Unkown Device
when i uninstall its driver Installed again automatically. and removeable disk is shown in my computer.
now how pc companion will detect it?
when i dissconnect it its again, press back key and plug in datacable it again listed as uknown device in device manager.
You need to perform the above steps with the phone connected in flash mode (connected whilst off and holding the volume button)
