Rebooting Arc
Rebooting Arc
Hi all,
had my xperia arc since aug/sept last year. originally had problems with random rebooting which seemed to stop after a software upgrade.
But now it seems to have started all over again. it's favourite time for rebooting is about two minutes into app usage (and it dosen't seem to matter which app)
its running 2.3.4
i've restored it back to the factory settings but as soon as i install any app from the market it starts again
i;ve done the removing of batteries and sim cards and the problem persists
it also does it on some phone calls which is rather embarrassing !
any information would be grateful as the phone is fantastic while it works !
regards
13 REPLIES 13
go to settings -> about phone -> check the Build Number
sorry for the delay
the build number is 4.0.2.a.0.42
i've narrowed down the rebooting to after market apps at about 2mins into the app
and the odd long phone call !
also every time i change netwoek mode it loses all signal although vodafone asssure me the signal is good, although they don't seem to know anything about wdcma  !
the only option it actually works on is wdcma(preferred)/gsm
any help would be nice !
backup everything and see if the latest update its available 4.0.2.A.0.62
Update Service (SEUS)
http://dl-www.sonyericsson.com/cws/download/1/110/61/1309763183/Update_Service_Setup-2.11.7.13.exe
Make sure you backup everything
Settings -> privacy -> Back up my data and Automatic restore should be selected
and also
Use one of these links to download the
Backup & Restore app
or
http://www.elita-clan.com/downloads/backup_and_restore_v010935.apk
http://www.elita-clan.com/downloads/backup_and_restore_v010935.apkor
How to install it
You need to
download IO File Manager
download the backup & restore app, transfer it to your SD card, use OI file manager to find it -> tap on it -> install it
Contacts
open your phonebook
on your computer
Apps
Don't worry so much about backing up your apps
on your computer go to
market.android.com -> log in -> click on My Library -> and send all your apps to your phone
market my library.JPGmarket my library 02.JPGmarket my library 03.JPGmarket my library 04.JPG
SMS/MMS
if you don't want to use the backup & restore app then
Install "backup SMS" to back up your SMS and MMS to your Gmail
or your SMS use
"backup & restore SMS"
or for your MMS use "Save MMS"
Call Logs
And for call logs this is great
Other ways to install the "Backup & Restore App"
an even Easier alternative
download the app, transfer it to your SD card
Download Apk Manager
W251bGwsMSwxLDEsImNvbS5tYWdtYW1vYmlsZS5hcHAuYXBraW5zdGFsbGVyIl0.
open "Apk Manager" and voila select the apps that you wan't to install
another alternative to install the Backup & Restore app
download the apk on your computer, send it to yourself through email, make sure you send it to your Gmail
now on your phone
wait for the email, once  you get the email, open it, and instead of downloading the attachment it will allow you to install it, voila, done
or
soory, still rebooting 2mins into anything downloaded
am i being stupid or is this an issue that can't be fixed ??
lets try to narrow it down, take the SIM and SD cards out, and see if the same problem occurs
ok, removed botrh cards ...
and i can'tr use the after apps as their on the sd card !
which  apps? didn't you just repaired your phone with SEUS and you didn't installed any app?
