Hi all
I brought my z5c on dicember with 5.1.1 stock, never have a problem since i updated to marshmellow 1 month ago, now even after the second update released for bugfix (!?), i have random reboot where the led flash red 4-5 times.... it's a problem of this version of marshmerllow??
thanks
Your phone it's out of battery, connect the phone to a wall charger > press and hold power & volume up for 10 seconds > let it charge for 2-3 hours.
mmmm the last time telephone rebooted it was at 70% of battery!
@Alred82
I have exactly the same issue. I get a reboot on average once a day, much more if the phone is working hard (eg navigation).
Nobody seems to have a solution, although I have not yet had formal contact with support. I have the latest update to Marshmallow, and have tried a software repair.
@uliwooly
Thanks for your suggestion, but it's not associated with low battery, and in fact happens often when the charge is high and connected to a power supply (eg when driving).
i can try, but when happen the problem the phone freeze for few seconds...and then reboot.... so i think is not connected with low battery or a battery problem...
there is a (safe) way to return to 5.1.1 ?
Contact your Local support but you should repair the phone with PCC to narrow down the issue.
Bridge (for Mac)
Thank you i will try
but what the repair do in detail? Only a factory reset?
Factory reset it's not the same as repairing the phone with PCC as the later will reinstall android.
I'm having the same problems. Oddily enough 90% of the time when I watch YouTube 1080p clips for longer than 7 minutes. Anybody experienced the same problem with YouTube? It did happen once before while just browsing the internet using Chrome as well.
