My xperia go still reboots randomly. How come it seems that I'm the only one with this problem. anybody out there who experience this? When playing music or just on stand by. it reboots. I used ICS and it was worse. I flashed GB back and the reboot problem is not that much now but when playing music it reboots Do you think it's a software problem or the parts inside? NEED MAJOR HELP
hi,
reboots of device usually cause by an error... probably memory leaks and application issues as well. have you tried repairing your os installation.
i suggest you get back using ics instead. test your phone with minimal applications installed. you can use a memory manager tool to identify which program is killing your phone - where most of them are running in background as services. if you do not need them all the time - then might as well kill them using these tools.
try to clear your cache also, delete .tmp*.* folders on your internal storage. reboot and test again
I'll update you on the results thanks!
