I have a problem with the radio on my xperia miro ... it appears to be working but I cannot catch any radio signal. All I hear is noise. Android version: 4.0.4 Build number 11.0.A.5.5
I travel to work and I listen to it every day. What can I do to fix it here in Serbia? Please help me!
I recommend that you first try your phone with another headset. The headset is used as antenna so this might be a problem with the headset.
If you have the same problem with another headset, try updating/repairing the phone software using PC Companion.
Good Morning,
I have the exact same problem. I have tried more than 10 different headphones, have repaired the software several times and nothing.
In the mean time, I have red several reviews in the web and everyone seems to have identified this same issue. I think that this is probably a hardware issue, instead of a software issue.
Is Sony doing anything about it ?
Regards,
Jorge
