As far as I know, the Z5P supports Quick Charge 2.0. However, while my Z4 tablet goes into 'quick charge' mode with the UCH10 charger, my Z5P seems to charge regularly.
The Z4 Tablet displays 'charging quickly' when connected to a QC2.0 adapter. However, the Z5P displays 'charging'. Does the Z5P require a special cable for QC?
I've tried both a UCH10 adapter and a QC 3.0 certified charging station.
Hi @silencer51,
You are correct, the Xperia Z5 Premium does support Quick Charge 2.0. As long as you use the cable that comes with the UCH10 charger then your phone will charge faster than if you where using a regular charger.
Is your device charging faster using then UCH10 compared to a "regular" charger?
I'll also see if I can get some confirmation on what message that should be displayed while charging using Quick Charger.
