hi
i have a pb in my z2 ..it is new one ...i have the last version andriod 4.4.2 and i did all the mise a jour
when i test my proximity switch in the phone it is always ON ( i use the *#*#7378423#*#* > Servise Tests > Proximity Switch) and in the diagnostics in the phone ) and the proximity always ON ...when i put my finger or remove it does not respond ....there is no thing change it is always ON plaese help me
When you make a phone call and hold the phone to your ear does the screen go blank - If it does then the sensor is fine and if not then you need to either return your device to the place of purchase or contact Xperia care http://www.sonymobile.com/global-en/support/contact-us/
And one thread is enough - Please don't spam the forum
when i make the phone in my ear it will be black it is lock it is oky now but the problem when i want to finishh the call ...and make it far of my ear it is stay black and lock i cant stop the call the porximity stay on it will never be off untill the person i speak with him stop the call
Try performing a system repair as this will often fix issues - This will factory reset your phone - Should the issue not be fixed then either return your device to the place of purchase or contact Xperia care http://www.sonymobile.com/global-en/support/contact-us/
Start PC Companion and select Support zone then Update my phone/tablet then in Blue Repair my phone/tablet and follow the onscreen instructions - When prompted connect your phone still switched off holding volume down or back button - This should start the repair or reformat process
You now have two accounts - Choose one to keep or one will be chosen for you (The 2nd account will be banned)
thank you for your answer i will try to do that ...for the account i will delete one ..i have pb in net
there is no change i stell have the same pb ....please helpe
As I said above - Should the issue not be fixed then either return your device to the place of purchase or contact Xperia care http://www.sonymobile.com/global-en/support/contact-us/
Hi, If you have double tap to wake selected ... the screen does not light up after a call (so you have no clue unless hit power button) ... to get the proximity sensor working you have to unselect tap to wake feature ... hope this helps
