When the sensor(always on) is on,my front camera is blinking.Is it a board complaint or Update error???My updated version is 15.3.A.1.12
I see, again full of bugs, pfffffffffffffffffffffffffffffff.
How recent?The phone needs 2-3 days to adapt to new software conditions.
3days
Well,if you repaired already,there is not much you can do.Sometimes it can take up to 1 week to adapt.You must also consider taking the phone into service.
I found proximity sensor blinking when my phone has a missed call.
To simulate this issue please give missed call to Xperia-L phone from another mobile.
Now, just watch the sensor.
The blinking can be stopped by just calling manually.
proximity sensor not work on my xperia L????:smileysad:
What is the solution??
problems about proximity sensor solve when you do factory reset after update
1) with the last upgrade 15.3.A.1.12 the phone after making a call or receiving a missed call proximity sensor stays on
2) the video camera in low light flashes
3) photos in low light while turning out quite hailstorms Manual mode iso 400 can be improved.
_________________________________________________________________________________
1) con la ultima actualizacion 15.3.A.1.12 el telefono despues de realizar una llamada o recibir una llamada perdida el sensor de proximidad queda encendido
2) la camara de video en condiciones de poca luz parpadea
3) las fotos en condiciones de poca luz salen bastante granizadas aunque activando el modo iso manual 400 se pueden mejorar.
