There's a problem with the proximity sensor when making calls. It doesn't work or takes some time to deactivate the screen when I put the device near my ear during a call. The result is that the notification bar is pulled down by the touch of my ear and other widgets or settings are "tapped". This was not happening with the Kit Kat as far as I remember. I already tried the Diagnostics and it shows that it works fine.
I hope it's fixed in the .283 firmware which is about to start rolling. If not it should definetely be fixed, at least in the upcoming Android 5.1 upgrade! It's really frustrating!
I just came here to post about the same thing. There's definitely a delay between when the screen turns off and when the digitizer turns off such that you can still send touch signals with the screen off for a second or two. Is anyone else having this issue?
Hi there Vasilis_K & camdecoster have either of you tried running a software repair on PC Companion?
it happened to me too. sometimes it didnt turn off, but it was rare. But yes, there was a more delay when i got off my phone from my face. Hated it. they did the same in xperia sp. So i downgraded to kk.
That's not possible for me at the moment as my bootloader is unlocked. I don't think it's a bad installation as I flashed the image from Sony without any modification. This started on the first lollipop build and it continues on this one.
@ SophiaW
Yes. Didn't help. I don't think it's an issue of OS installation failure. It's definitely a bug. I've read quite a lot of reports in other forums too.
@uliwooly wrote:flash kitkat and report back
This phone is my daily driver, so I can't flash another OS version and lose my setup. I can tell you that this didn't happen for me on Kit Kat.
Same issue with mine...
KR
