I've noticed that at high brightness levels when the background is dark(and not only with dark backgrounds) at the top right of the screen glows yellowish. The rest of the screen is almost black. (as I think it should be). The yellowish glow spreads from the top right (slightly from the top center) to middle right,forming a yellow triangle. It's horrible!
For example, I notice it a lot when the camera is turned on
Does someone else same happens?
Now I can not send you any pictures because I'm at work. I will try take some pictures at home today
Regards,
Xabi
I would definately like to see some pictures regarding this situation. Once you post them ill let you know what I believe could be the problem.
Thanks Jake for your interest.
I got the pictures but I could not post them yet. Today I hope to do so.
Jake, here are the pictures
Additional Information: It was bought on 16th July in Spain.
Thanks for all
On the pictures I can see a slight white line going down on an angle from the Sony logo, is this a trick from the light or can you also see this line?
I also noted such screen condition in my phone ( Xperia P ).
Does screen need replacement ??
In fact, when i turn on phone, and SONY logo is visible on boot screen, lots of yellowish green tint is visible on screen corners and sides. ( when looking from about 45degree angle, less visible when looking direct,
Really the line you comment is not white, is yellowish like the rest. (Error of the camera). Yes, I can also see the line. This line forms the triangle of yellowish glow which I commented at the beginning of this post.
Dude even my Xperia P has same prob n the same place in the screen.. when eva i switch on my mobile i can see the yellow shade.. Is this a Faulty Display??
Your case is a classic LED backlight bleeding, and it is bad.
Send it back for repairs
Just for the record: I don't have any of these issues.
