I'm sorry for disturbing you like this but I'm really need help.
I've bought my phone for 3 weeks. And it has 2 problems:
1. when I ended calls, the phone went black nothing can make it responed again until restart the phone.
2. my phone's touch screen has not working propertly, it's going wild, jumb to anything and anywhere on the screen. I put the power button to calm it down but it's not last long.
How can I fix my problem? Please help me on this.
Thank you for your time
Try performing a system repair using PC Companion as this will often fix issues - This will factory reset your phone and erase all data so best to backup before you begin
Thank you so much, I will try to do it right now, I will try it and respond as soon as possible
Sorry for disturbing you again, but my problem isn't better. It's still the same. Please help me, what I should do now??
your first problem, it is because of the screen cover, it hides the proximity sensor
Hello SamParker .
I am Facing the same problem of touch screen . my phone is behaving abnormally and and doing anything i am very fed up with this .
do you got any solution for this problem ? i already done so many things i done with the factory reset and also done with the software uptades.
but its not working well for me .
please help me with this , i m in a big troble ...
wating for your reply ...
