Hi guys,
recently had my vivaz U5i dropped and the lcd went, so bought a replacement (ebay) and installed it, all seemed fine except when i place the digitizer on top of the lcd it makes it soo dark i can hardly see even with brightness on full, the display on lcd itself looks fine just when i put digitizer on its place i cant see!!
The actual digitizer seems to be working ok, and funny thing is if i place it sideways on top of lcd i can see thruw fine!
Do you think its the digitizer that has is gone as well and need replacing or can it be a problem with the actuall screen, ie a polarity issue or something??
Dont want to go buying as digitizer if its not the problem!
As well does anyone know where i can get a new rf antenna cable replacement? can wire it directly myself but if i could get a cheap new cable it would be ideai, just seem very hard to find one!
Thank you guys for any help.
http://www.formymobile.co.uk/vivazdisassembly.php Perhaps this guide might help answer your questions about the LCD screen.If not, use the email address at the bottom of the page to conatct Rob Lee about the screen and any spares you might need.Hope this helps.
hi, thank you.
I have disassembled and assebled it ok so thats not unfortunately the issue.
OK, try the email address for any questions that you may have.I have used this before and found it very helpful.
hey,
unfortunately because i did not purchase the lcd from them, he seems reluctant to help, which i can undersand.
Guys who i bought lcd from dont answer me as well, and like i said, the actual lcd seems to be working fine, so guess im in a pickle......
Well, you can always use a repair centre.
Did you find a solution. I am having the same problem.
