Hi, my xperia have a problem, is ask me that give format to theinternal memory, and he show that is empty, but i have files there. So if you have the answer, please help me. thanks
Have you formatted your card already? - If you have take it out and connect it to a Pc and download, Install and run a program like Recuva for example and scan your card which possibly will recover file etc from it-
If you haven't formatted your card then remove and connect it to a Pc - If your Pc asks you to format then do not, Maker a note of the drive letter assigned to it,
then open a command prompt normally Search or run and type cmd
Once open you will have a black box type in the box the drive letter followed by chkdsk /f so for example your card has been given a letter of H so you would type H chkdsk /f then hit enter and hopefully this will correct any corruption on your card making it once again accessible
the PC just show the SD card, no the internal memory, before of this problem he showed me both.
Remove the SD card from the phone and connect it to a Pc using a card reader then follow my above post
[the PC just show the SD card, no the internal memory, before of this problem he showed me both.]
You need to change your USB settings on the phone to MTP (not MSC).
Settings - Xperia - USB Connectivity - Connectivity Mode
Then, PC Companion will be able to show both.
