After I updated my Xperia M2 for Lollipop, Instagram began presenting Wi-Fi connection problems. Whenever I unlock the screen, appearing notifications Instagram, but when I open the images, the failure error appears connectivity and you need to cycle the power of the Wi-Fi connection on your smartphone ...
But other Apps, continue to function properly without any error ...
Whenever I see the pictures published, several images are not displayed, and shows the charging failure ...
Before upgrading to the Lollipop in the Android KitKat there was no problem, but after upgrading, I just have headache !!
If I had known, we would have these errors, I would not upgraded, because I can not go back to the KitKat !!!
Reinstall the latest update with PCC and report back
Bridge (for Mac)
After upgrading to the lollipop, nor PC Companion, is not recognizing the Smartphone.
Already I desistalei the program three times and installed the 3 times, and always shows the notification that needs to be updated, but when I upgrade the PC Companion, the program says it is already the latest version !!
After the update for Lollipop, only it appeared problems ...
