Problems with ICS update!!!
almas_xperiaU
Hi guys,
After the ICS update, the following problem have cropped up...
1. sometimes, even while charging the battery meter does not increase, even though after unpugging, it shows a full charge.
2. The camera takes about 2-3 seconds after the on-screen key press before capturing the pics.
3. The  button on the earphone(which I used for changing the tracks) behaves absurdly and wildly most of the time, it can be hardly used for changing the track now.
4. The phone seems laggy at times, especially when a live wallpaper is set-up.
Any help from any member will be highly appreciated...Thanks
Smailchenko
I would recommend to do a software repair via Sony update service then do a factory reset , it would help a lot Slightly_smiling_Face
