Problems regarding Xperia J :(
shin_arman
Plzzzzz i need help Slightly_frowning_Face  i upgraded my xperia j with pc companion as told before but it has been updated to jelly bean...but the problem i am facing is that the phone does not recognise my sim card...it leaves signal.....internet connection problem on it.....wifi problem Slightly_frowning_Face these are the main things they are not working as it is if sim used in other devices it is working smoothly....PLZZ HELP !!!:smileysad: again and again i m trying to fix my phone bt no use :smileysad:also upgrading to jelly bean is mot satisfactory......bcoz evrythngs similar nothng new in it.....now i m regretting by getting this phone.......PLZ HELP ME Slightly_frowning_Face !!!!!!!!!! THANKS ANY HELP WILL BE APPRECIATED Slightly_frowning_Face
Sam
Legend
Legend
Based on the information you have provided it appears that the problem occurred after the update and as such it was likely a problem installation that has caused this. With this being the case please attempt a repair:
To repair the phone software
1.     Install PC Companion on a Windows PC from Support
2.     Turn on the phone, and connect it to the PC using a USB cable.
3.     In PC Companion, under Support Zone and click Start.
4.     Under Phone Software Update, click Start.
5.     Click repair phone.
6.     Follow the on-screen instructions.
