I have a big problem on my xperia v, and I need help from sony because I live in another country, in the case in Brazil, in xperia v there any jtag it work?
I'm with the problem qhsusb_load, destroyed bootloader, flashing was 11 cm and corrupted the bootloader, porfavor help me is completing two years I'm looking for
thank you so much
Try performing a system repair as this will often fix issue after an upgrade - This will factory reset your phone
Start PC Companion and select Support zone then Update my phone/tablet then in Blue Repair my phone/tablet and follow the onscreen instructions - When prompted connect your phone still switched off holding volume down or back button - This should start the repair or reformat process
guy is impossible , because fastboot and flash does not work
Then you have a hard bricked device and it is now only good as an expensive paper weight
