Problem with throw
WYMK
Problem with throw
I have a sony bravia EX645 40 inch television and I have a xperia Z with 101.1.1.A.253. Currently I am experiencing a throw problem. the video throwing works fine, but I cannot use the seekbar at all, doing anything with the seekbar will just be pausing or unpausing the video, eventually out of sync and stopped the playback on the television. Music works fine. I can also use the remote control to fast forward or rewind the video. Can someone please advise me what happened?
2 REPLIES 2
Rickard
Have you also tried updating the software in your TV? It looks like there's an update available for your TV here: http://esupport.sony.com/CA/p/model-home.pl?mdl=KDL40EX645&template_id=1&region_id=3&tab=download#/d....
If updating the TV doesn't help, does the problem occur with other devices as well? If you have a computer you could for example install XBMC from www.xbmc.org, enable UPnP control in XBMC under settings and then try Throw to the computer.
WYMK
the xbmc works, but it is kind of jumpy... like when you seek on the xperia it doesn't really jump to where you want, it skipped through a couple of frames and then goes to where you seek. On the TV however, i updated the software and it is still not able to seek through the device.
