Have you cleared data in settings-apps-all-facebook?
You may need to perform a software repair using PC Companion.The process will erase all internal memory.You might need to charge your device for about 1-2 hours before so the device has at least 60% battery.
Things will change,just wait a little more. It is normal that after an important system update,it will take some time to settle.
