Hi all,
I have an Xperia L for a few days and I have a problem when charging the phone. After connecting to the charger,the battery power increases normally up to 100%. However, as soon as I disconnect it from the charger, battery power decreases immediately up to 82%. It is quite frustating since battery duration is quite short.
Could anyone help me to fix this problem?
Thanks!
let the battery drain to 5% then charge it all the way to 100%, do this 2 times or so.
also, are you using any battery apps?
Thanks uliwooly. I will try and I will tell you what happen.
About the apps, I am using Battery HD, but is just a monitoring battery application, it has no control about the phone.
uninstall this apps
taskillers
task managers
antivirus
battery apps
ram apps
booster apps
Yes 3rd party apps only creates many problem.
