Ok, so I purchased this Xperia P two days back. All's well, tested everything using the test code too. This is something I noticed only after Jellybean update because I only looked at it after that point. When taking an image from the camera, all's well in daylight, but in dark areas, the image becomes too dull *THE MOMENT I tap the capture key or button* Before the moment I tap the capture button, everything looks good on screen through the lens, but the moment i tap the capture key, it's all way too dark. Let me tell you precisely what I mean. When not having tapped the capture key, dark areas look good, as if the ISO value is 800. The moment I tap the capture key, the final image is as if the ISO is 100 only. THAT dark. And this isn't the "partial black" problem from ICS. I tried several different stock ROMs to fix this but it didn't go away. Even tried a stock ICS ROM but same issue with dark areas. Is it just me going through this bizarre problem or does anyone else here experience the same? Moreover, does anyone have ANY idea what the heck I can do about this? Please help with this. Thanks.
If anyone needs a video of this happening, I can create and post here. I am desperately in need of help because the camera isn't brightening the final image as it shows before clicking the capture button. The moment the focus is tapped or capture button is tapped, the entire image becomes very very dark. I have tried third party apps too. Same problem with them too.
this problem exits in its orignal Firmaware or u have facing it after a update. i watched sevral videos on youtube . i will tell u which rom to try ok.let find that video for you.
Problem existed in its original firmware I think. I can't say for sure because I noticed the problem for the first time after the JB update. Any help would be appreciated, thanks a lot.
na kar yar pehly say he problem no way . ok i will find a youtube video and firmaware version also .ok...:smileyhappy:
Thanks. I created a video of my problem. My friend recorded this video with his xperia pro. You can see the problem in action here: https://www.youtube.com/watch?v=NQsu5Ol_ZgA
Hey ! buddy i fin these check these out i will tell u more when i get back !
PM u links !!!
