Problem with resetting phone lock code
Hi, I have a problem with resetting my phone lock code in vivaz model. I tried to reset to original settings, but the default code of 0000 doesn't work. I keep getting the code error message. What should I do? Pls help. Thanks.
5 REPLIES 5
Dr_Chris
Try 1234 and 1111.Otherwise, try using all the available digit spaces (6 or 8?), i.e: 000000 or 123456.
Hi Dr Chris,
Do you know if there's any maximum number of attempts allowed to enter the phone lock code? For example, for the PIN, more than 3 incorrect attempts will block the SIM card. I've been trying continuously to figure out the phone lock code, but I just can't remember. Thanks.
Dr_Chris
You need to have it unlocked at a service centre if you don't remember the phone lock code.
Lazarovg
Hello together,
how ca i reset a forgotten lock code on a  Vivaz phone.
I need it for a reset of factory settings since an upgrade of software is not working ... the phone restarts if connected to the computer.
Thanks,
G.
Lazarovg
What are the settings to update my phone software directly from the phone?
