x
Problem with Music widget on lockscreen bug
fmcc789
Although it was originally working, the lockscreen widgets for the walkman app and spotify app no longer appear when music is playing. The clock widget is instead always shown, although there is a slight flicker when you first turn on the screen as if it is trying to switch to the music widget, and clearly there is a bug in the software.
Has anyone else experienced this?
44 REPLIES 44
jmss10
Cant evento add Spotify widget to the lockscreen, cause theres few widgets to add
Steffarno
Thx a lot m8. You made you made my Big jambox by jawbone  woth of 230 hard earned dollars work again. The play/pause, previous- and skip song bottons didn´t work because of the bug. But now they do.
kedarpowar
Thnx ..darshan ..its a problem caused due to smart key..uninstalled ..now i cud see walkman player keys..play/pause...fwd/rev...keys ..thanx a ton ..tried a lot of things ..only ur solution worked ..thanx.a.ton
Mangineer01
I just had this problem on my Sony Xperia Z3 Compact. Disabling Smartkey did the trick. Thanks so much guys! :smileysmileythumbsup: I have a feeling fixing this might not be high on Sony's priority list.
Srinath_27
When i press + symbol in my lock screen there is no Walkman widge. Is there any other way to add the widget to the lock screen.I'm using Xperia M and I'm facing this problem since the last update.
