Although it was originally working, the lockscreen widgets for the walkman app and spotify app no longer appear when music is playing. The clock widget is instead always shown, although there is a slight flicker when you first turn on the screen as if it is trying to switch to the music widget, and clearly there is a bug in the software.
Has anyone else experienced this?
This worked for me - thank you very much...
Thanks ! One year later we still having the same issue but I was able to solve it with your help, thanks again
Uninstalling smart key solved the issue, many thanks
didnt have smart key installed,
what i did was install smart key and then uninstall... problem fixed
I'm using the Jays Headset Control set to advanced and still have these issues with my three button a-Jays 5.
Is this a bug with the KK 4.4.4 framework or how smart key software handles the lockscreen interaction?
