i have a problem with the camera it doesn't launch from the shutter key directly the camera either gives me a "camera not available" error when i unlock the phone or i have to unlock the phone to launch the camera what to do??????
Settings-apps-all-camera,force stop and clear data.Restart and check again.
Does it work on safe mode?
the camera launches normally after a long press of shutter key in safe mode but that's not the same in normal mode what to do???
It means that's a third party app acting up, either unisntall one by one until you find the culprit or repair your phone with PCC
Bridge (for Mac)
Performing a software repair using PC Companion.The process will erase all internal memory.You might need to charge your device for about 1-2 hours before so the device has at least 60% battery.
thanks guys problem solved after repair -actually it was a phone reset- but any way the camera went to launch from the shutter key as before so thanks for every contribution from everyone to help me solve the problem
Awesome.
