I have a phone Sony Xperia arc S and strange problem on it. It sometimes happens that the applications run by themselves! The touchscreen as it goes crazy and starts to act on its own! When I put the phone into sleep mode and re-run the problem goes away but after a while it reappears. What's the problem? Is it a bug in question, or something else? Sorry for my bad english, I hope you understand my question
Make sure ICS is not available for your phone
________________________________________________________________
SUS ( Sony Update Service) ... download and install it on pc and follow the on-screen instructions http://www-support-downloads.sonymobile.com/Software%20Downloads/Update_Service_Setup-2.11.12.5.exe
or
Both the links are same
Thank you for very fast reply! I'll try it right now!
I upgraded my phone on ICS 4.0.4. My problem is thus solved! Thanks again for your help!
