Hi guys,
I m facing problem while using 8gb micro sdhc card. phone just switches of whenever i insert the sd card and i hv to remove the battery and restart the phone again. Phone just keep on restarting itself and whatever i store in the card get currupted.
please help me in solving this problem
Is this a new card or one that came with the phone? Have you formatted it/re-formatted it? Can it be read in your PC with a card reader adaptor?
Heey!
I am suffering exactly the same issue!
I have android 2.1. I changed the 2GB SD card that came with the phone and I am trying to install a 8 GB SDHC but it behaves exactly as described. Phone switches off itself, SD card gets corrupted etc..just could make my phone stable again by using my old 2G card.
What is going on here?
Having the same problem here with my new 4GB Micro SDHC. ¬¬ Put the 2GB that came with the phone and just works like nothing happened..... HELP
Format SD Card & Reinsert
I did that, and the same problem continues....
Thanks for the help.
Main problem was with the SD card i bought, after using the new card everything is working fine.
Hi, I've got a similar problem: I just bought a Kingston micro SDHC 8GB but it doesn't work well on my X10 mini pro. When I take a picture the phone apparently writes to the SDHC card but gives an error when I try to visualize the photo. It works well when doing a read-only operation (listening to music).
I have formatted (FAT32) the SDHC card with my notebook (WinXP) and on the phone too, but the error remains. My phone firmware is up to date (2.1-update1). Any ideas?
There is a similar discussion on Facebook:
http://www.facebook.com/topic.php?topic=22154&post=114212&uid=35313373389#!/topic.php?uid=3531337338...
I also got problems. When I take pictures the files are broken and so on. Also the phone reboots itself and so on.
I researched on the net and it looks like the problem is with Class 4 cards and X10 Mini/pro hardware.
I think it is hardware problems. So sending it to repair may help or maybe not if it is software/firmware problems.
