problem s in 4.3
rasu_xperiaT
problem s in 4.3
1. My xperia t has become  noticeably  slow. specially call log phonebook messages take time to load
2, while receiving an incoming call it sometimes hangsup for a while.
3.NFC notification ion gone
Am running on  .205. Any suggestions ? Thanks
5 REPLIES 5
profile.country.RO.title
_alexdon_
1.Maybe you have apps acting up: task killers,battery savers etc.
2.It could be the same reason as above
3.NFC icon is not available to all devices,it depends on the firmware and where it was released.
alexdon
rasu_xperiaT
What should I do ???
I use android assistant. No battery saver or live wallpaper.
And I moved apps from phone to SD to free up rom.
The main problem is during an incoming call sometimes after receiving the call it gets stuck for few seconds.
NFC notification bar was working till last update.
_alexdon_
Does NFC still work?I remember a staff member told us some time ago about the icon being removed at the request of networks.
You could try to boot in safe mode,see if the phone works fine:
http://talk.sonymobile.com/t5/FAQ/How-to-boot-your-phone-into-safe-mode/m-p/348008
alexdon
rasu_xperiaT
HmmChecked. NFC works.
But the call log and contacts take time to load and specially while receiving a call it hangs sometimes which is disgusting.
i have quite a few apps installed. will uninstalling them would help.
Tags (1)
faisal3dfx
Did you updated chrome browser? If yes the try this go to settings-->apps-->All-->chrome. Uninstall updates and force stop the app. Restart your phone. See if this help you fix the call receiving problem.
Thank you
