my phone is not starting .it continuous restarting . First it shows Sony then Xperia and then again showing sony then xperia it continues showing .it seems it again and again starting .what i do.My phone is not rooted.
Last known firmware version you knew?
You should check whether it's the SD or the SIM that makes bootloops...
Try removing either one of these to check the problem...
Regards,
Trubo
