Issues using SD card as default internal memory
Tsalcon
I bought a Sony Xperia Sola and an SD card and I can't install any applications in it. Is there any way to use the SD card as default internal memory and not only for files storage?
Regards
4 REPLIES 4
You can't use SD card as default internal memory, but you can transfer large games and application files to SD card with apps such as Directory Bind. You have to be rooted through.
Tsalcon
That means I'd lose the phone warranty right?
Trubo_XL
That's exactly yes! But if you unroot (so that Service Center can't trace down your ROOT activity), you can get the warranty back...
Undercover XD
Regards,
Trubo
Tsalcon
Oh ahah.
Thanks xD
