problem in updating to ics ... :(
nikunjsola
hi guys ... im from india and i received a msg from my sony pc companion saying that ics update is available . i followed all the procedure .. at the stage where pcc asked me to hold down volume key and insert usb nothing happened ,the phone just went into charging mode ... i tried updating with sus also but at the same stage again same thing happened . as mentioned in some other post i also cleared the data of mtp app and again tried updating but again while plugging the usb the phone just went into charging . the battery is fully charged btw . Slightly_frowning_Face pls help .
10 REPLIES 10
You have to keep pressing the volume button down while connecting usb cable and it should start updating right away.
nikunjsola
yeah man that only i did ... i pressed the volume down key and inserted cable ...  again nothing happened .
AroyaExcel
you sure ? Which color with your notification light ? green or blue ? have you ever unlocked the bootloader ?Try to use flashtool with downloading a FTF,you can find it on XDA website.
nikunjsola
at first the notification light turns green.... and then it turns red and just goes into charging mode .... no my bootloader is not unlocked .... i want to avoid rooting my phone ... so please can u help me with some other method.
Sorry, but you wrote the same and I can't understand what you. Did you 1. just pressed volume down and after that plugged in cable? that's what I did girst time. 2. Did you kept pressing volume down while pluging in cable? that is correct way. sorry again, but I couldn't understand it from your reply
nikunjsola
yes i keep pressing the volume down key while inserting the cable .
AroyaExcel
Please try using Flashtool ,if you want ,you can download the FTF (Rom) from  XDA(It's official),otherwise ,you can make the own FTF with updataing cache by Flashtool,don't worry ,it's ok .
Solaris
If your LED turned green for a few seconds, there's nothing wrong with the phone. The PC sync for update may not be working.
Download Sony update service and try with that. Alternatively try a different PC.
abhig10
The right way is to turn off your phone and wait for 30 seconds atleast. Then press the volume down key and don't release it until the software says. While it is pressed insert the micro usb into the sola and then you will get the notification on the screen to release the key.
I did the same mistake the first time I tried. If it doesn't connect try again. Or use the other one(PCC/SUS) then the one you are using right now.
