Hi abdelmogheeth,
Welcome to the community,
Are you able to advise what troubleshooting you have performed so far?
Try this step first.
Menu > Settings > Apps > All > Smart Connect > Clear Data
If this does not help, can you boot the device in to Safemode and test it and let us know the result?
In this case I can only really advise that you perform a backup of the device and then a software repair to reload the device. Try the instructions below.
This is done with either PC Companion or Bridge for Mac
Here's how to run the repair on PC Companion:
2. Phone Software Update.
3. Start.
4. Repair Phone
5. Continue
6. Accept data removal
7. Next
8. Wait for prepare
9. Select Phone
And Bridge for Mac:
2. On the Main Window select "Xperia > Repair Xperia Device".
3. Ensure the phone is charged and select "Ok" in the following window.
5. Wait until the initialising step is finished the continue as below.
7. Follow the connection steps that appear, ensuring that you are holding the relevant button down before during and after the connection phase until the update/repair begins.
