My phone is Xperia™ E4 Dual
When calling my customer service mobinil number (110) call The emergency number (1)
The change in the number 110 to connect to the 1
I can not connect to service customers
My device The last updated Software
Please Solution
I'm not really sure I understand what you mean. When you try to call the number 110 it calls the number 1? Could you elaborate the issue a bit more please?
When dialing 110 is the change to the emergency number
I can not dialing 110 from my phone
Hi @MohamedSaad5
Do you have the same issue when you dial other numbers or it´s only the problem when dialing number 110 ? Keep us updated please.
I understand - So here in the UK it's 999 or 101 so for you the emergency number is 110 which doesn't work
To contact the customer service number on 110
what should I do ?
Samuel xavinux Thommo
Thank you for your help
xavinux
110 only
Hi @MohamedSaad5
So it´s not a problem with your device. Remove the SIM card and insert it again. Then try to dial number 110, if it´s not possible, I suggest contact your mobile carrier. I´m at disposal for any question.
Experimented but not useful Why should I do ?
Is it permissible to contact support and modify the new software
and The possibility of amending the voices of Touch His voice annoying
xavinux
Many thanks to you to follow up on my problem
