problem in charging
problem in charging
when i switch of the mobile it automatical on and it display charging. but i could not connect the charger.i try to repair it the same proble will continue in switch off and connect the usb please give some solution
Can you clarify your problem...
Are you saying that your phone automatically turns on when connecting it to the charger? If so this is normal behaviour for your unit, it cannot be charged whilst switched off.
Or are you saying that it won't charge when connected to the charger at all?
