problem in back cover of Z1
Moremont
Hi
today I found that, the corner of back cover my xperia Z1 had opend! (about 2 mm)
In fact I bought it 10 days ago! and I recharged it only 2 time.
I leave my trust to sony mobile brand by this event!
sorry SONY Slightly_frowning_Face
14 REPLIES 14
Hampus
I'm sorry to hear, but in this case I suggest that you contact nearest service center so a technician can examine your unit. You can contact your local support for further information about nearest service center and/or how you should proceed in this case:
Moremont
I'm sorry to say that, the Sony hasn't any valid service center in my country, IRAN!
you can see this dark truth in your link.
Rickard
I don't know the language so i can't check but if you can't find any contact for your country on http://www.sonymobile.com/ir/support/contact-us/, use this emailaddress: questions.ir@support.sonymobile.com
Moremont
thanks alot
I will inform you the result of this contact.
Moremont
Hi
I have no replay from that Email address: questions.ir@support.sonymobile.com
Is it a valid support center in IRAN?
Sam
Legend
Legend
Did you receive an auto reply with an SR number?
What are your thoughts about this forum? Let us know by doing this short survey.
Sophia
hey, you can look into the back cover and find the reason. It's caused by deformation of the back cover or the melt of the adhesive sticker on the back cover?  Then when you can contact the service center, you can explain the situation and to make sure what they can do .
Have a good luck!
Moremont
No
I got nothing!
Moremont
Yes
In fact I found it. the weak sticker is it's reason. and now the back cover had deformed and I think after the stick it, water can leak to Z1.
any way I don't expect this problem by sony after 10 days
Thanks Sophia
