Hello,
I bought my Xperia Z1 about a month and a half ago. I haven't put my Xperia Z1 in water and I didn't drop it on the floor so that's not the problem. But whenever I want to unlock the phone I press the powerbutton but 10 seconds later it responds or not at all. When the phone is finally unlocked and I want to lock it again the button works perfectly, so the problem is only with unlocking. Also when I have an incoming call when the phone is locked the screen doesn't light up, so I can't answer it. Besides that, and I'm not sure if those two things are related, when I turn my phone 90 degrees the screen doens't always rotate automatically, same when I take a picture with the camera. Both problems showed up at the same time so I don't know what's going on exactly, but it's getting annoying since I've only had the phone for a month and didn't drop it or put in under water. I hope someone recognizes this problem and could tell me what's wrong with the phone.
Thanks in advance
How about if you boot in safe mode.does the same occur?
Thank you very much, it works perfectly fine now
I uninstalled a couple of useless apps and the button responds like it should be.
Great.
