Portable WIFI Hotspot disables WIFI
TonyBro
Recently when I try to enable the portable WIFI Hotspot by turning WIFI on  (icon turns blue on off changes to on), going to More/Tethering and portable hotspot, clicking Portable Wi-Fi hotspot (check mark turns blue).
However when I go back to Settings Wi-Fi it has been turned off.
the hotspot cannot be detected.
3 REPLIES 3
Hampus
When you enable your phone as a portable Wi-Fi hotspot, it will disable any ongoing Wi-Fi operations including the Wi-Fi itself. When you use the phone as a hotspot, the network that will be shared is the mobile network via your network provider.
jonlm
That's normal, your phone can only receive or send Wi-Fi one thing at the time.
BrotherTony
Thank you all.
Had a seniors moment and forgot the 2 are mutally exclusive. At the same time forgot I changed the password.
Hope I did not waste anyones time
Tony
