plz help me
mohammed8888888
plz help me
i had recently updated my xperia J , but the WI-FI did not work any more
can u help me to avoid this problem
10 REPLIES 10
profile.country.RO.title
_alexdon_
What do you mean that wifi does not work?Can you still turn it on or you just cannot connect to a specific network?
alexdon
mohammed8888888
no, it is not working anymore
Tags (1)
_alexdon_
Did you go to settings-wifi and drag the little circle to turn it on?
alexdon
mohammed8888888
yes but it does not find any wi-fi network
_alexdon_
Maybe you should just forget your wifi network and add it again.
alexdon
mohammed8888888
i forget and rescan to find it , but no network is seen
i tried it with two or three networks but my device still can not find any one
mohammed8888888
may it be a problem with the device software
can i restore the old software of the device
Jake-SonyXperia
Hi Mohammed8888888,
With the information supplied, I suggest performing a quick restart to your router first and then a restart to the handset, once this has been done try connect the Wifi to the handset, if you have further issues, try using the link below for Wifi troubleshooting.
WiFi Troubleshooting.
I hope this helps.
What are your thoughts about this forum? Let us know by doing this short survey.
mohammed8888888
plz tell me can i restore the previous software of my device or not?
