Xperia ZL is Playstation certified. i downloaded the necessary app. when i try to login it says "this service is not available in your region" if its not available whats the point in owning it?
I dont know then i already told you that i bought mine from the grey market before the official launch, so maybe that's why i have one already installed on mine
he could probably flash the UK firmware but I don't know if that will grand him access to the PS store, it most likely allow him to install it
It wont really work. Earlier i had tried with my xperia pro to connect to SEN. had the same error even with the UK firmware. so I wonder how could he get i worked. and installing the app is not a problem.
you won't be able to make it work, check the XDA forum, perhaps there's a way around it but I doubt it
Can anyone from Sony confirm when Playstation NotWork will start to work in my country for Xperia Z?
Is there any concrete reason why Sony separates its users on better and worse and therefore allows ones to use Playstation mobile while do not let the others ???
I am from Poland.
