After upgrading my Sony Xperia Z3 to Android 6.0 version of the phone it has become impossible to work:
1. Phone ceased to hold the battery. Discharging 3 times more often!
2. Remove the Stamina mode and ultra Stamina.
3. Removed convenient mode without sound with the setting timing (using only the vibration mode is available volume buttons)
4. When outgoing calls after dialing the phone slows down 15 seconds, after which only is a challenge!
5. I can not log into the application "Yandex Disk." Writes: "The application is stopped Yandex"
6. It was not easy camera control:
A) button before the photo and video were there and did not have to make unnecessary movements
B) is up to the shooting mode you will reach so do not have time ... (((
C) of the photo editor removed the ability to add text. well, or well hidden.
I bought a year ago, could not get enough - get enough (((DISAPPOINTED !!! phone has become absolutely squalid !!!
Topic edited by Rickard
I'm sorry to hear that.
One possible reason for higher battery usage is that one or more of your downloaded apps are not fully compatible with the new Android version or needs to be reinstalled. To test if this is the cause you can restart the phone in safe mode. In this mode it will not load any 3:rd party apps.
Factory Reset resolved my battery drain issue.
I also hope that they will reintroduce the Stamina mode and the other battery saving features.
Unfortunately, the Android system started again to drain over 60% of the battery.
Perhaps indeed an app is doing this but I'm not using exotic ones...
Same issues here. Major battery drain and noticeable heat increase immediately after update to Android 6.0.1.
Charge will not even last 12 hours without using phone. Please fix this Sony.
